Why my monitor turned black not showing anything
My monitor turned black not showing anything but connecting to another monitor shows that it works perfectly fine on the background. Tried everything but no use.
With the laptop turned on and a display showing on an external monitor, switch the display back to the laptop screen and then try shining a flashlight at an angle, close to the screen and check if you can see any images at all on the screen.
They will be very faint if they are there at all, so trying this in a darkened room may help to see them.
If you can see images on the screen, then there's a backlight problem with the screen.
This could be due to any of the following, in no set order:
Here's the hardware maintenance manual for the laptop that will help. It shows the procedures to remove various components so that you can check the above.
If you can't see any images on the screen, then there's a problem on the motherboard and further testing using the schematics will be required to find out what's wrong.
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 82
