Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
Speaker is fully charged then stops working
I have fully charged the speaker and then I go to use it and it'll work for maybe 30 minutes and then it shuts off and won't turn back on again. For a while it was dying and then after a couple minutes I could power it back on again but now it just completely shuts off. Works perfectly fine whilst plugged into the charger and it shows that it's fully charged. Please help!!
Sounds like a failing battery, you would need a working battery to check/repair. Make sure to get the right battery for your model. Ifixit has a guide for battery replacement here - again not sure the exact model: JBL Boombox Battery Replacement
It may be enough for you to get at the battery and check the numbers so you can get the right replacement.
Hope this helps
sarah mitchell crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 38
