The fifth-generation Elantra debuted at the 2010 Busan International Motor Show in April 2010. The fifth-generation Elantra (2010-2015) added a two-door coupe variant in addition to the standard four-door sedan model. These Elantra vehicles included six-speed automatic or manual transmissions.
My car is shifting intermittently and the engine has stalled in places like parking lots. Since I am not an expert in car repair, I took the car to a parts store to get it scanned. When they scanned it, they noted 2 codes were present: P0420 and a sensor code, but the way it was presented is unclear and was not easily understood.
What else can I do to find the issue and get it fixed at the lowest possible cost, especially since it's an older Hyundai with poor resale value?
I took the car to AutoZone, it has a P0420 code - but I do not think this is related to my stalling issue as it was on for some time before this, potentially with the same code.
Of course! Here’s a simplified, beginner-friendly version of the plan for fixing the issues with your Hyundai Elantra:
Step 1: Start with the Oxygen Sensors (O2 Sensors)
Why?: The P0420 code usually means the oxygen sensors are having trouble. These sensors measure how much oxygen is in the exhaust and help your car’s engine run smoothly. They often go bad after 100,000 miles, which is around where your car is at now.
What to do:
Upstream O2 Sensor: The first one to try replacing is the upstream oxygen sensor, located before the catalytic converter. This sensor is more likely to be causing the issue.
Cost: A new oxygen sensor usually costs between $50 to $150.
DIY Option: If you’re comfortable, you can replace it yourself. There are lots of YouTube videos showing how to do it. You’ll need basic tools (like a wrench or socket set) and you can buy the part from an auto parts store.
Step 2: Clean the Mass Air Flow (MAF) Sensor
Why?: Sometimes, the "sensor code" the store mentioned could be about the MAF sensor. This sensor measures how much air is coming into the engine and helps it run smoothly. If it gets dirty, it can cause stalling and rough idling.
What to do:
Clean the MAF Sensor: You can clean it using a special cleaner that costs around $10 to $20. Just spray the cleaner on the MAF sensor (it’s easy to access, and usually near the air filter). Be careful and don’t damage the sensor.
How Often?: Cleaning the MAF sensor is something you can do every year or so for good maintenance.
Step 3: Check the Catalytic Converter
Why?: The catalytic converter is the part of the exhaust that helps reduce pollution. If it’s clogged or broken, it can be expensive to fix. This is usually a last resort if the O2 sensors don’t fix the issue.
What to do:
Temporary Fix: Some auto parts stores sell "catalytic converter cleaners" you can add to your gas tank to clean it out. But this usually only helps if the converter is a little bit clogged, not totally bad.
Cost: If you do need to replace it, a new catalytic converter can be $500 to $1,500.
Last Resort: Don’t worry about replacing this unless you’ve already replaced the O2 sensors and still have the same problem.
Step 4: Check the Transmission Fluid
Why?: Low or dirty transmission fluid can cause shifting problems, which is one of your symptoms.
What to do:
Check Fluid: Look at the transmission fluid level and color. It should be a bright, clear red color. If it’s dark or low, you might need to top it up or change it.
Cost: Changing transmission fluid is usually cheap, under $100 for fluid and a basic filter change.
Step 5: Do Basic Car Maintenance
Why?: At this mileage, some smaller things might need attention to keep your car running smoothly.
What to do:
Spark Plugs: Replace the spark plugs if they haven’t been done in a while. Worn-out spark plugs can cause rough running and stalling.
Air Filter: Check and replace the air filter. If it’s dirty, it can make your car run poorly. Air filters are cheap (under $20).
Step 6: Get Help from a Mechanic
If you try replacing the oxygen sensors and cleaning the MAF sensor but still have problems, it might be worth taking your car to a mechanic for a second opinion. Ask for a diagnostic check (it’s usually around $50 to $100), and they can help pinpoint the issue more clearly.
Final Tip: Shop Around for Parts and Quotes
If you decide to get repairs, always ask for quotes from different mechanics or auto shops to get the best price. Some places charge more than others, so shopping around could save you money.
Summary:
Replace the O2 sensors (start with the upstream one).
Clean the MAF sensor.
Check the catalytic converter (but leave it as a last resort).
Check the transmission fluid and top it up if needed.
Do basic maintenance, like replacing spark plugs and air filters.
Get a mechanic’s second opinion if the problem persists.
If you need any more details on how to do the repairs, or if you want me to help you find the right parts, let me know!
Refined:
The P0420 code usually means the oxygen sensors are having trouble. These sensors measure how much oxygen is in the exhaust and help your car’s engine run smoothly. They often go bad after 100,000 miles, which is around where your car is at now. Check the upstream oxygen sensors near the cats. This often causes this code, unless the car is losing performance which usually points to a bad cat. This is not hard to change yourself at $50-150 for the sensor on most cars.
In some cases, the "sensor code" the store mentioned could be about the MAF sensor. This sensor measures how much air is coming into the engine and helps it run smoothly. If it gets dirty, it can cause stalling and rough idling. You can try cleaning it with MAF cleaner, but this can potentially damage it in some cases -- albeit unlikely. If the car gets worse, it was likely damaged.
The catalytic converter is the part of the exhaust that helps reduce pollution. If it’s clogged or broken, it can be expensive to fix. This is usually a last resort if the O2 sensors don’t fix the issue. You may be able to use a cleaner, but this will only work in some cases -- however, it is cheaper then a cat ($500+ for the cat replacement). Some people choose to leave the code be forever if the cleaner works well on older cars.
Low or dirty transmission fluid can cause shifting problems, which is one of your symptoms. However, changing it is risky if it has never been done before on a car with this many miles as the fluid is usually keeping it alive. Only do this as a last resort.
Depending on how recently the spark plugs were changed, they may be past due. Changing them is a cheap fix that may help fix the misfires and shutdowns.
crwdns2944067:05crwdne2944067:0
What have you done? Have you scanned the car?
crwdns2957956:0crwdnd2957956:0 Nick crwdne2957956:0
No, the check engine light is on. I do not have any codes.
Can you buy a low cost scan tool such as an Innova scanner, or take it to a auto parts store to get scanned?
If it helps I have a 2013 Elantra.
