Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
Mac won’t charge
Back again. So I did a battery replacement recently and it wasn’t turning on. Only while connected to the charger. Turned out, the battery cable wasn’t properly connected. Now, the battery is connected and it displays at 65%. I tried testing the charger and it works on other devices. Before the battery was properly connected, the Mac only turned on because the charger was plugged. So the connection was there. I unplugged it and the computer turned off. This is when I got the advice to fix the battery cable. The Mac is now at 60% and I can’t get it to charge.
What can I do now. The system says Thunderbolt: not active. Is there a way to get the thunderbolt active again? Is it the battery? I have not updated the computer recently, is it possible this will fix it??
If the system states the port is not responding then the given port may have a problem. Did you try the second port? If it to is not responding then the port assembly is not connected or the ribbon cable is damaged MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board.
It still would be useful getting that CoconutBattery snapshot I was asking you about.
crwdns2886500:0Replace one of the thunderbolt connector boards from the left or right side of your laptop.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$19.99
hey svpreme crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 51
