Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
Why my printer dont pull papers it say erro
my printer it doesnt pull papers
Update (01/17/25)
why my printer dont pull papers to print it say error
@chosenapos11160 what exact model is your Epson printer and what exact error message does it display?
@oldturkey03 I put up a preliminary answer for now, pending the model and knowing if it has problem sounds like grinding.
This is more of a preliminary answer, pending knowledge of the model. The first thing I've done in these cases is to try better paper -- say for example I'm using the Staples TruRed paper and they changed suppliers where it no longer works well to the point the mech struggles with it, I've had good luck with the Hammermill paper (Hint: The Epson branded paper is Hammermill, save your money and buy the Hammermill in bulk unless you get a good deal on it) on difficult print mechs. Sometimes the paper you're using is just too cheap.
If that doesn't work and you have a "desktop" (read: CMYK non photo) topload model, get a flashlight and make sure the rollers are in good condition. If the rollers are good but have dust, you may need to get cleaning sheets on these models as the rollers aren't accessible for much of anything with topload Epsons; that said, for bottom feeeders, you can access them with a damp rag and clean them manually. If the rollers are cracking or the printer is several years old, the rollers may be worn out.
If the rollers are worn, it's probably not cost effective to fix as the problem really begins to show after 5+ years old, and on old models like the C84 and older the ink isn't available anymore anyway. By the time the roller wear is a major issue, it's usually nearing 10 years where OEM ink availability becomes a future problem (the rule is Epson sells the OEM ink for 10-15 years; once it's discontinued the 3rd party supply becomes a future issue as they rely on OEM Epson cores). Even old reliable models like the R200 (desired for the CMYK+LC+LM ink configuration and easily reset smart chips eing T048, not the newer chips which hard lock at 25%), they're nearing the point of being a non recommendation for similar risks.
A. Does it make the attempt to pull the paper but it cannot? (You hear the sound of the paper feeding mechanism)
Or
B. It does not initiate the paper feeding process at all and just displays an error message? (No movement or sound of the paper feeder mechanism)
If the scenario is A, you may have a worn out or dirty feed roller. The rubber on the feeder tend to get dirty and slippery thus losing their grip. You can clean them to restore their surface.
Your printer might have a damaged feeder mechanism.
If your printer is a top feeder, it is quite common for debris or small objects such as pens, coins or paper clips to fall into the paper feeder and can prevent the paper from coming into contact with the feeder roller.
If your scenario is B, then there might be a communication error with the printer. Check your cable, try a different USB port, uninstall and reinstall the printer driver. Also check your print queue for pending print jobs.
ncubenichomatongo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 98
