Apple's sixth-generation smartwatch, with optional cellular connectivity, released September 18, 2020. Model A2376, 44 mm.
New battery won’t charge
New battery 🪫 is showing 1% and the display symbol is a red bolt indicator. Watch charges fine with old battery. Watch reset just fine but it will not charge properly. Constant rebooting on the new dead battery.
Similar problem here: new battery. Watch still doesn't show signs of life. Gets hot while charging. Nothing on display after trying all button combination.
When you connect the puck onto the watch does it even respond?
Yes the red circle bolt turns on
@joemech83 - Jump to Step 14 in this guide Apple Watch Series 6 Battery Replacement double check the connection, is the connection firm, could one of the contacts or the cable damaged? Otherwise you’ll need to get a replacement battery.
Joemech83 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 53
