Repair guides, disassembly, and troubleshooting information for the fourth generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-040.
Since replacing thumbsticks, my Bluetooth range is practically zero.
I recently installed some replacement hall effect thumbsticks into my V4 controller. Since I did the replacement, the bluetooth range has gone to almost nothing - it won't connect to the PS5 and only my Mac will see if if I rest the controller literally on the laptop. As soon as I move it away, it stops working.
I've clearly broken something. Do these controller have an antenna for the bluetooth? If so where is it on the motherboard. I'm wondering if I broke a connection or two.
Any help much appreciated :).
I found the solution here: https://www.reddit.com/r/consolerepair/c.... I had the component missing pictured which is odd as that is nowhere near the part I was working on. I wonder if that particular component is prone to falling off. Anyway I believe it is a resistor, not a capacitor, it's blue not brown like a capacitor nor is it black or grey like an inductor. I bridged the gap using some carbon contact paint which would introduce a bit of resistance and so far it appears to have worked, I have bluetooth range again!
That is very good to know just in case i need to replace with hals in future and accident like yours happens.
So you basically just capped capacitor/resistor spot with some soldering. Shouldnt cause too much of an issue
Yes that's right I just needed to get the signal through.
Damien Green crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 424
