My MG 2520 printed and stoped the triangle light flashes.Changed ink
The carriage sounds like it moved but doesn’t
@bobmorris35868 let's see if our printer guru @nick can help you with this.
@oldturkey03 Got it. Hopefully it isn't a 5B02 or similar issue :/. Every single one of these cheapos like the MG tricolor machines have the worst sized pads and the OP's symptom of a sudden hard stop can point to it. Canon ACTUALLY kind of warns the user that the printer's death is impending, at least; but that should be a warning to refill your current carts with bulk ink and not buy new carts... But we know why Canon doesn't warn users to use it up in that stage.
Check for a 5B00, 5B02 or similar family of waste ink errors and the early warning codes related to waste ink. When you change the ink carts, they always purge a small amount of ink to prepare the cartridge. If your waste ink pad is 95% full, for example, that cartridge change will very often trigger it, and what makes it hard is the WC NVRAM percentage can be high (80%), but the printer can survive 10 cart changes, sometimes less. There is no good way to determine when it dies with a hard stop due to waste ink. NONE!
NOTE: 8 blinks=waste ink pad is full.
See if WIC Reset Utility can be used to reset the counter if this is the case. If you cannot, the printer is effectively ewaste. The official Canon utilities WILL NOT RESET IT, and is known to not do it -- it's intentional. On these, its potentially a permanent flag if the printer is considered "disposable" and this is one of them. However, try the Canon reset tool known as V3800 if you want to give this a shot, but you will also need to put it in service mode first; it may somehow work.
This procedure may work for your model if the tools do not and it has service mode access. If it cannot be done, it's a permanent one-time flag that cannot be reset, even by Canon.
If it's not a waste error, something is in the platen path or the ink carts are loose. Check for obstructions or damage, and make sure it isn't catastrophic -- if it's something like paper, removing it will probably solve the issue. The other issue I see is generally bad ink carts. Try another set and see if it still occurs; if it does, then you may have a bad carrier contract strip. Try cleaning it with alcohol, but if it doesn't work, it may physically fail.
Bob Morris crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 98
