iPad Air 5 SMC BSC failure panic
My iPad keeps crashing. The panic log can be found here. I believe the repair technician may have used a heat gun as opposed to an iopener or hot plate, so this may be the cause, but idk. If anyone has access to the Pro version of https://panicfull.com, screenshots would be appreciated. I already tried the windows download version and all it said was a NAND issue, but I’m not sure that’s accurate and want to double check.
Panic log: https://drive.google.com/file/d/1lnIAx3U...
Have you found and further Information or Solution for this Problem ?
crwdns2934271:0crwdnd2934271:0 Dirk crwdne2934271:0
@dirkdiegmueller Are you getting the exact same panic? Usually on an iPhone this panic is related to a specific sensor that's not checking in. But the sensor codes are not well documented on iPad so it's trickier to know.
crwdns2934271:0crwdnd2934271:0 Alisha C crwdne2934271:0
Not ecactly the same, my panic Is smc bsc 0x200000 based on liquid damaged iPad Air 11. Cleaned up and changed some corroded Parts. Now iPad Is booting and loading, only this 3min ugly pinky screen makes me Crazy …
