The 5th Generation iPad Air was announced on March 8, 2022. It features the M1 chip and 5G connectivity.
iPad Air 5 SMC BSC failure panic
My iPad keeps crashing. The panic log can be found here. I believe the repair technician may have used a heat gun as opposed to an iopener or hot plate, so this may be the cause, but idk. If anyone has access to the Pro version of https://panicfull.com, screenshots would be appreciated. I already tried the windows download version and all it said was a NAND issue, but I’m not sure that’s accurate and want to double check.
Panic log: https://drive.google.com/file/d/1lnIAx3U...
crwdns2944067:04crwdne2944067:0
Have you found and further Information or Solution for this Problem ?
@dirkdiegmueller Are you getting the exact same panic? Usually on an iPhone this panic is related to a specific sensor that's not checking in. But the sensor codes are not well documented on iPad so it's trickier to know.
Not ecactly the same, my panic Is smc bsc 0x200000 based on liquid damaged iPad Air 11. Cleaned up and changed some corroded Parts. Now iPad Is booting and loading, only this 3min ugly pinky screen makes me Crazy …
Don’t worry, we’ll figure this out together and fix it.
SOLVED: apply constant pressure along all edges of the screen forever. fixes crashing until pressure is removed. I have the overpriced $80 iPad case from Mous but it applies so much pressure along all edges of the screen that it doesn't crash after it's been shoved into the case. (tested for 6 months continuously, no crashing). When removed from the case crashing symptoms will return in 30-60 minutes.
If my storage is below 48-64GB used (on 256GB iPad) then it doesn’t crash. As soon as I get close, it will start crashing under increasingly light workloads, until it crashes from the Lock Screen.
And your Panic.full shows smc bsc failure in Sensor Array ?
I can save this problem,the only way is get brand new battery on ipad。so easy。
Dead battery never results in Panic …
Is there a possibility that It's the battery cable damage, not the battery itself.believe or not.Have a try.
jack crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 399
