The Xiaomi Redmi 7 is a low-budget smartphone by Xiaomi released March 2019. It has a 6.26" IPS LCD display, a 12 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 632.
Mengapa sinyal gps hilang
Sinyal gps hilang dan sinyal wifi lemah
Translation Indonesian - English
Why is the gps signal lost? Gps signal lost and wifi signal weak
Please use english
You could try replacing the antenna cable
@yadimartin you can use whatever language you like. It does not matter to us and do not let anybody tell you different. Here, everyone is welcomed!
You did not tell us if you have checked your GPS and WiFi on a different network connection. Try it at a place that you know has perfect signal. See if that makes a difference. The other thing to try is to switch your phone into Airplane mode. Then Wait for about 30 seconds and switch the Airplane mode off. See if that improves its function. After that you would want to go ahead and clear your cache. Always make sure that you have the latest firmware for your phone installed.
You should also try to start your phone in safe mode to rule out a bad 3rd party App. If it works in Safe mode, you know it is a bad App. That would mean that you have to delete the ones you installed on your phone.
To place your phone into safe mode you do this:
  1. Turn on the phone
  2. Long press the volume down key
  3. "Safe mode" will appear in the bottom left corner of the phone screen
Translation
@yadimartin Anda dapat menggunakan bahasa apa pun yang Anda suka. Itu tidak menjadi masalah bagi kami dan jangan biarkan siapa pun memberi tahu Anda yang lain. Di sini, semua orang dipersilakan!
Anda tidak memberi tahu kami apakah Anda telah memeriksa GPS dan WiFi Anda pada koneksi jaringan yang berbeda. Cobalah di tempat yang Anda tahu memiliki sinyal yang sempurna. Lihat apakah itu membuat perbedaan. Hal lain yang dapat dicoba adalah mengalihkan ponsel Anda ke mode Pesawat. Kemudian Tunggu sekitar 30 detik dan matikan mode Pesawat. Lihat apakah itu meningkatkan fungsinya. Setelah itu, Anda perlu menghapus cache. Selalu pastikan bahwa Anda telah memasang firmware terbaru untuk ponsel Anda.
Anda juga harus mencoba menyalakan ponsel Anda dalam mode aman untuk menyingkirkan Aplikasi pihak ketiga yang buruk. Jika berfungsi dalam mode Aman, Anda tahu itu adalah Aplikasi yang buruk. Itu berarti Anda harus menghapus yang Anda pasang di ponsel Anda.
Untuk menempatkan ponsel Anda ke mode aman, lakukan ini:
Nyalakan ponsel
Tekan lama tombol volume bawah
"Mode aman" akan muncul di sudut kiri bawah layar ponsel
Yadi Martin crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 33
