Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
MacBook Pro 13" m1 vertical and horizontal lines
I am getting vertical and horizontal lines on my display MacBook Pro 13" m1
Can you add a picture to your post? It will help if we can see what you're seeing.
Have you recently opened the case to look inside / replace something / or other reason?
Maybe the LCD cable has either come lose, not connected fully, or developed some fault.
Check that 1st, and if the issue still persists then you have a deeper issue somewhere.....
Here is the guide for MacBook Pro 13" Two Thunderbolt Ports Late 2020 Display Assembly Replacement
Disconnect the battery before doing anything!
@livfe - Lines on the screen points to a damaged LCD display. As he is stating both horizontal and vertical the screen has a puncture point within the middle somewhere where the two meetup. If it was only one direction it’s often a damaged T-CON cable to LCD panel.
Davidson Christmas crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 93
