After announcing the discontinuation of the Durango after the 2009 model year, Dodge released an Internet site and teaser photos of the third-generation Dodge Durango on August 16, 2010.
Why is my Dodge Durango leaking oil?
Why is my 2017 Dodge Durango leaking oil
Darrell, can you give us more detail on where you're seeing the oil leak? There are quite a few possible places for any given engine to leak oil from so the more you can tell us about what you find, the better we can help figure out what's going on with it.
Are you seeing oil dripping on the ground? Is there oil running down the side of the engine? Are you finding the oil level low in the dipstick? Those are the kinds of questions that will help us help you.
Without much detail as to what was done prior, anything we can offer here will be limited. That said, you can do a few things to get an idea. The first thing I have always done on Hyundai/Kia and FCA/Stallantis engines is I will take a few spark plugs out and check for oil consumption; granted the FCA/Stallantis vehicles that don't have Fiat engines aren't as prone to it (see: Jeep Renegade for something with the problematic Fiat engines), but it happens on these due to some cost-cutting on the Stallantis era FCA vehicles. You do not need a fancy borescope camera -- something like this will do the job. If you see oil on the spark plugs, that's a dead giveaway symptom it's burning oil.
You also want to check the valve cover gasket and the oil pan gasket. The one I usually check first is under the engine bay since it's plain as day once you take the beauty cover off. For the lower pan, jack the car up and check around the pan. The oil pan one is pretty easy, and you can usually get replacement gaskets for $10-20. Sometimes, the manufacturers use a high-temperature gasket maker at the factory, in which case, you will need the high-temperature variant if you need to "reseal" the pan due to the gasket maker failing (make sure you scrape the old gasket material off with a blade before putting new material on, and DO NOT GET IT IN BOLT HOLES!). The valve cover part can be purchased at any auto parts store or online, but you need to search based on the engine code in your Durango.
Darrell Bowen crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 111
