Cara memperbaiki LCD yg menghitam How to fix a black LCD
Saya punya xiaomi redmi 5 plus yg lcdnya ada titik hitam, bagaimana cara menghilangkannya atau harus ganti LCD, terimakasih
Translation Indonesian - English
I have a Xiaomi Redmi 5 Plus whose LCD has a black dot, how do I remove it or do I have to replace the LCD, thank you
I have a redmi 5 plus and I charge it and it is not turn on nonething
@vaskopap0qe, It's hard to say exactly what's wrong with your phone with just the brief description you've given. If you've verified that your charger and cord work by either trying different ones or using them on another device, then it appears your battery has no power.
Does your phone give some indication that it's charging when you plug it in? Does a computer recognize it when you connect it?
It could be you've got problems with the charging port or the battery, but these are just guesses at this point. You could try replacing either or both of those parts and see if that helps.
Manuales / Xiaomi Redmi 5 Plus / Drums (Battery) - Nadie Me Llama Gallina
Manuales / Xiaomi Redmi 5 Plus / Auxiliary plate (Charging port flex assembly) - Nadie Me Llama Gallina
@dienzchannel without seeing your LCD and only going by your description, this sounds like a bad LCD. You will have to replace it. Since iFixit does not yet have a specific guide for this, use this guide It is written in Spanish so use a browser that will translate it for you, if needed. Replacement LCD are readily available at many online places.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@dienzchannel tanpa melihat LCD Anda dan hanya berdasarkan deskripsi Anda, ini kedengarannya seperti LCD yang rusak. Anda harus menggantinya. Karena iFixit belum memiliki panduan khusus untuk ini, gunakan panduan ini Panduan ini ditulis dalam bahasa Spanyol jadi gunakan peramban yang akan menerjemahkannya untuk Anda, jika perlu. LCD pengganti tersedia di banyak tempat daring.
Saat Anda mengerjakan ponsel, ambil banyak gambar. Setelah selesai, ambil gambar tersebut dan buat panduan untuk iFixit. Itu akan membantu orang berikutnya yang memiliki perangkat dengan masalah yang sama seperti Anda. Membuat panduan ini mudah dan menyenangkan. https://ifixit.com/Guide/new Komunitas iFixit akan menghargai ini.
Perbaikan adalah Perang terhadap Entropi!
Dienz channel crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 242
