Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
only turns on when charging
it only turns on when charging and then turns off when unplugged. i did just replace the logic board. probally didnt plug a wire in properly or smth. Help
Install our trusted friend Coconut Battery to see what info is given (Post that up on here so we can also have a peek) as hopefully the issue is just with the connection from the battery to the board. I suggest then to go over the MacBook Air 13" Late 2020 Logic Board Replacement guide to check everything is connected up correctly. if there is still no joy after these 2 steps then one of the experts will give some follow up help.
just posted the Coconut Battery report. please check
this is the Coconut Battery report
According to the CB report the battery is either not connected properly or there is another issue going on, 1st step is to go over the battery connection and the connector that goes from the I/O board to the main board (A black plastic type part that lays over the fan to see if they are connected fully.
ive fixed it. the battery wasnt connected properly.
Karim Osman crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 34
