Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
What is this connection responsible for?
Hello!
Some time ago my macbook air got soaked in the rain. I dried it, properly cleaned it, everything was working (except battery and trackpad is a bit wonky). The only problem was that during the cleaning I saw that the connection that I circled in the photo, was completely rotten, disintegrated, the chip to which the cable connects fell of from the corpus. What is this cable responsible for? I could not find any info on the net.
Also, at the same time, my keyboard started to disconnect from time to time. It was not working for a week ,then started working again for few days, now stopped working again. Could it be because of the swelled battery? Or this implies that there is another connection which is starting to break down?
Thank you very much for your answers!
It’s a bit confusing! The MacBook Air 13" (A2179, A2337 2020) Trackpad Cable carries both the keyboard and trackpad data to the logic board and that other cable is the power lines for the keyboard backlight which you can see here MacBook Air 13" (A2337, Late 2020) Upper Case with Keyboard
The small logic board these cables connect to is the 2020 Keyboard Trackpad Board 820-02288-A I don’t think the keyboard backlight or the keyboard cables are replaceable. I would just replace the fully uppercase assembly as it’s a lot less work and less of a risk of damaging things, you would still need the Keyboard Trackpad Board if it’s damaged.
crwdns2886500:0Replace a torn or damaged cable that connects the trackpad and keyboard to the logic board compatible with the model A2179 or A2337 2020 13 inch MacBook Air laptop. Part #821-02663.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$14.99
crwdns2886500:0Replace an upper case and keyboard compatible with a late 2020 model A2337 MacBook Air 13 inch laptop. Includes the keyboard and palm rest area.crwdne2886500:0
$299.99
Donatas Šimeliūnas crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 29
