A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
1x Antenna cable would not reattach
I recently replaced the screen on my MacBook Pro (for the 2nd time).
During reassembly, I could only get 2 out of the 3 tiny antenna connectors to seat correctly.
I decided to chance it and booted it up as is. Both Wifi and Bluetooth worked fine; so my question is;
  • What will be broken because one antenna connector is not plugged in?
Missing an antenna means missing a MIMO path, both range and throughput will be impacted.
Thanks... that makes sense. Will this impact affect both Wifi and Bluetooth? I assume yes, but thought I'd check.
@mrtimshel - MIMO is a WiFi standard as such only effects your WiFi if it was the second WiFi antenna that you left off. If you damaged the Bluetooth then the lack of a proper antenna reduces its range as only the antenna connection stub is acting as your antenna limiting its range.
Tim Pring crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 54
