Not enough disk space? Need a backup solution? External drives provide you with extra storage in your office or on the go. Learn how to repair them here.
My LG Hard drive cannot open
2.5 External HDD HXD5 320gbs. my father uses this. he does not know how it happend.
The device can be identfied by the computer, it is present, but upon clicking there will be an infinite loading with an error.
please assist
So the drives port logic is seen, but access to the data is not possible.
@skippythescout "infinite loading with an error" what error do you get? You said it is an external drive. Have you removed the drive from the enclosure yet? Post an image of the labels on the drive with your question. Adding images to an existing question
Hard drives have a set of weakness as they have a motor to spin the platters and within the arm there is a solenoid to move the arm across the platters to then allow a very tiny set of magnetic heads to read the magnetic flux laid-out as a track (one per side times the number of platters) and one of these areas can fail and in doing so makes the drive not work.
Do you hear any noise when you first power up the drive? You should hear the spinning of the platters ramp up, then a click when the head assembly unlocks its self, followed by the sound of the head assembly seeking the inner track.
Do you hear these sounds and if not which.
Skippy the scout crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 118
