New Battery install not charging.
My Son has a refurbished macbook pro 2015 with 13" retina. He's had it for about two years with the only complaint being the battery life. At some point this year he used bootcamp (I assumed) to run windows 10 as his operating system - without saying anything to me, because he thought it would be easier on his battery. Here is what was happening with old battery:
Would only charge when computer was powered down.
On full charge would last about an hour before the battery was out of juice.
Important note - when plugged in the magsafe charger DID light up.
My thought was OK why don't we just change the battery? I have a little experience as does older an son. Bought new batter set to work. gave the inside a cleaning to remove dust, crumbs, your basic schmutz. Carefully of course.
After removing old battery, a major chore but got it done, installed the new one, put everything back the way it goes and followed the directions which said to charge for five minutes then turn on.
Here is what happened:
When plugged in the magsafe did not light up.
After the five minutes the computer did power on (great!) and showed a 47% charge. Question: DOES IT COME WITH THAT MUCH BATTERY LIFE?
The battery indicator did not show that the battery was charging although we could feel heat at the source - meaning - inside, where the magsafe plugs in it was quite warm.
Powered down rechecked that everything was IN PLACE as it is supposed to be. decided to plug it in again and give it ten minutes this time. Came back ten minutes later, powered up - still no light on magsafe before or after powering up computer. Still no charging indicator on battery icon. The battery at that point is at 42%. It is definitely NOT charging, it is discharging.
The instruction booklet, such as it is, had instructions for reseting the SMC - so we did that to see if that would make any difference and there was no change whatsoever.
Apparently Windows has a battery report (I don't know I'm a mac person) so we did that. It wasn't terribly helpful other than to show that there was a battery in existance (good) but it says CONNECTED STANDBY Not Supported - Is this the issue? If so, what does this mean? To me it sounds like the power to charge the battery.
The only other portion of the battery report with today's date on it shows where the computer has been turned off and on.
Another question is, would the Windows OS have any bearing on what is happening? What I mean is, if it were still running a Mac OS would I be experiencing anything different?
So I have an older Macbook pro was good condition except for the battery, that was running fine, except for the battery and I thought, Let's change the battery, now it's not charging at all! What are my options! Help please because I do not want to buy a new one!
I look forward to any and all advice that anyone has.
Update (10/29/24)
Under normal circumstances I’d be more than happy to do that. The problem is that the battery isn’t charging. Even not using it, it still discharges two hours ago it was at 38%
I’m worried that once the battery is dead I’m screwed! I won’t be able to check or do or try anything!
crwdns2944067:012crwdne2944067:0
Install Coconut Battery as no doubt @danj will ask to see what is displayed in there https://www.coconut-flavour.com/coconutb...
crwdns2934271:0crwdnd2934271:0 livfe crwdne2934271:0
@livfe You know me to well🥳
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
@danj I forgot to say gem of an app..... dan and his quick fire copy n paste techniques :D
@sis6598116 what board number is your logic board? Should be something like a 820-4924. You do have a multimeter?
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
I do have a multimeter (not great with knowing how to use it 😬 wish I would have paid more attention when my late husband was using it) the closest number I could find to what you described is 653-0194
crwdns2934271:0crwdnd2934271:0 Sis65 crwdne2934271:0
crwdns2934275:07crwdne2934275:0
