Headlight hi/low beam switch replacement
Replace hi/low switch on headlights of 2007 Ford 150 stx
@charlesharner sounds like you are talking about replacing the
ItemPart NumberDescription
1 W504041 Lower steering column shroud screw
2 3530 Lower steering column shroud
3 W506824 Upper steering column shroud screws (2 required)
4 — Upper steering column shroud
5 — Multi-function switch screw
6 — Multi-function switch electrical connectors (part of 14401)
7 3K359 Multi-function switch
Removal and Installation
This is how the service manual describes it.
Those that have replaced the switch know it is NOT necessary to remove the steering wheel or mess with the airbag. Check this video to see how to change it without the removal of the steering wheel etc.
While you work on your truck, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
crwdns2942667:0crwdne2942667:0 106
