The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
Motherboard issue: 3ds will run ONLY when squeezed
I'm thinking this is either a grounding issue, or possibly the sensor responsible for knowing if the system is secured is faulty. It could even be a screw that won't screw all the way in any longer...
For whatever reason, this motherboard will only turn on and run while the bottom left is squeezed. I replace the motherboard with another one that didn't have this issue, and I wouldn't have to squeeze it, so I KNOW this motherboard is causing the issue.
Has anyone experienced this or have any solutions to offer?
I’d take a wild guess and say that a connection is not making proper contact somewhere on your device. Check all of your connections make sure no contacts are broken, ribbon cables are broke, or traces are broke.
This is what I thought too, but the replacement motherboard does not need to be squeezed at all... I suppose it could be a port on the squeeze board that the cables go into, I'll try taking a closer look, but it's tough to see if something is loose or broken since everything is so small
@whisp96 :O OMG I HAD THIS SAME PROBLEM!! i could do a system transfer/nand when i got a new 3ds! i js used a big heavy cup! take @viiohl "s answer btw!
Whisp96 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 84
