Problema fps. Low fps
Ciao,
Sto giocando con la mia vecchia ps3. Ho provato a giocare a gran turismo e va tutto ok.
Su f1 2014 sto notando cali di framerate. Ho provato anche a cambiare disco ma il problema persiste.
Può essere un problema hardware?
Hi,
I am playing with my old ps3
I played with gran turismo and i noted no problems.
With f1 2014 i noted a lot problems with low fps.
I tried to change another disc(same videogame) but the problems are same.
Could it be a hardware problem?
Grazie. Thanks
Aggiorna (10/05/24)
Hi,
F1 is partial installed on the HDD.
I performed some tests with GTA and I noted zero lagging.
I tried to switch off the Mediaserver and changed the resolution at 720p.
Now F1 works very well... not perfect but it's ok.
I don't know if swap my HDD with SSD.
