The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
Problema fps. Low fps
Ciao,
Sto giocando con la mia vecchia ps3. Ho provato a giocare a gran turismo e va tutto ok.
Su f1 2014 sto notando cali di framerate. Ho provato anche a cambiare disco ma il problema persiste.
Può essere un problema hardware?
Hi,
I am playing with my old ps3
I played with gran turismo and i noted no problems.
With f1 2014 i noted a lot problems with low fps.
I tried to change another disc(same videogame) but the problems are same.
Could it be a hardware problem?
Grazie. Thanks
Aggiorna (10/05/24)
Hi,
F1 is partial installed on the HDD.
I performed some tests with GTA and I noted zero lagging.
I tried to switch off the Mediaserver and changed the resolution at 720p.
Now F1 works very well... not perfect but it's ok.
I don't know if swap my HDD with SSD.
Hi!
It also depends on the manufacture. Some games are just more stable then other games (or optimized for the PS3). Some games are asking more from the PS3 it's GPU then other games.
Does F1 installs on the HDD (partly)? Or does it completely run from the blu-ray? Otherwise an SSD can help! It saves loading times when installed on the HDD/SSD. I would go for a cheap SSD with like 120GB of space if you are using game discs. Otherwise 256GB should be OK. This because the PS3 is loading games from the disc most of the time.
This is probably the only thing you can do.
If you want you can upload a video regarding the issue.
SteR crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 76
