Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
Why is my printer saying no paper?
Epson ET-4760
why is my printer say no paper and it’s a tray full of paper? i brought new paper just to try it out and saying same thing
My printer said no paper in cassette
It is best not to add your problem to someone else's thread. You probably have a different unit and you are also not posting enough information. We are very knowledgeable, but we can't read minds. You need to draw us a picture as complete as possible. Otherwise, take it to a tech who can observe everything that is happening.
there is a switch that senses paper. You need to find it and determine why it isn't working.
Could be a bent actuator or defective switch or loose switch.
Based on Marilyn's comment, I had another thought -- If it is a dual cassette machine, it may be that you have accidentally selected the wrong tray for it to pull from. You could add some paper to both, or check your printer configuration carefully.
@rachelgree80709 here is the Epson ET 4760 Service Manual. The Paper Out error can be a failed PE or PW sensor. You do want to check those. Make sure they are clean and that the flex cable is properly connected etc. Check page 45 for the error and page 19 shows you the location for the sensor.
rachel green crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 38
