Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
CPU Upgrade i5 3.4 Ghz to i7 7700k?
I recently opened up my 2017 iMac with the core i5 3.4 GHz CPU to clean it up and put an SSD in it. I also decided to swap the CPU to an i7 7700K while I was in there. Everything went smoothly, but after the CPU swap, the computer wouldn’t boot. I could hear the fan, but nothing else really happened. I put the original CPU back in and everything worked fine. I closed everything up and decided to give up on the idea as I found myself lucky swapping the CPU twice and not breaking anything.
My question is: was the 3.4 GHz CPU upgrade in the first place? The official spec sheet shows all other processor options configurable to i7 except for the 3.4 GHz i5. I assumed it wouldn’t make a difference if the original CPU was a 3.4 GHz or a 3.5 GHz. I also bought the replacement processor secondhand so there’s always a chance of that being a bad one. I don’t think I’m ever gonna open the iMac again. I’d just like to know if the lowest spec CPU was the issue.
Thanks!
To start with your system's firmware only offers the MicroCode for the CPU's Apple offered which are these 2017 27" iMac systems - iMac18,3 So make sure you got the correct CPU
I'm a bit confused on what you are asking as you can see in the listing I've posted the 3.4GHz i5 is a supported chip but did you get the correct series as thats the core issue you need the Kaby Lake series.
Thanks for the answer. I must have overlooked the Kaby Lake series part… I just got a random used i7 7700K.
V.S. crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 126
