My Bose Headphone is not Charging
My head phone is not charging and it’s not turning on it was just fine but it doesn’t blink when I charge and doesn’t turn on what’s the issue
@devin7933 not sure how you are charging it but you want to make sure that the charger works. Next, check the charging cable connectors to ensure they are not bend etc. After that, check the DC-in jack on your headphones. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris by using a few puffs of air to clean it out. After that, it's time to open it and check the board for an loose wires and time to replace the battery. Bose NC700 Замена Аккумулятора
Well I will suggest you to checkout the following guide it might help you out in fixing the issue: https://www.boseapac.com/en_in/support/a...
Devin crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 229
