Introduced for the 2010 model year until the 2019 model year, the 6th generation Ford Taurus is a full-size 4-door sedan built on the Ford D3 platform.
Why is my air conditioning not working?
Says the refrigerant is full, and it's blowing hot air not just warm but hot and the heater works fine. ac Recently worked but rc relay I believe was changed and now it won't work.
@shantelmcguire does your AC compressor kick on? Have you checked the fuses to make sure those are working and how did you check the refrigerant?
Check the fuses and relays first. Use something like shown on here Let us know what you find out.
Okay so long story short my dad fixed the AC compressor relay I believe and he told me he had to empty the refrigerant so I'll have to put more in when I want ac, but no I did notice that the compressor isn't kicking on but then when I used the gauge set comes with the refrigerant it told me it was full and all my fuses and everything look good but now my engine light is turned on put a code reader up to it and long story short it says my thermostat which my car is for some reason running at Cold driving down the road not in the middle like it's supposed to be not sure if that has anything to do with it
shantel mcguire crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 43
