{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
Antennas and mounts came off motherboard….
Yesterday I was doing a repair on a 2017 MacBook Pro, and while I was disconnecting the antennas the mounts from the motherboard came up with the antenna cable. One of them came off correctly, but the others don’t look so good. I still see the gold needle in the middle is there a way a specialist can solder it or like a cheap fix of glue to still make it work without a MB replacement?
Update (08/20/24)
Can you take a photo of both the antenna and the connection to the board?
Dependent on the severity it might be a fairly simple repair that I would love to assist you with.
If at worst case you don't wish to repair it wireless USB adapters work too.
Yeah give me like 30-40 minutes til I get to work, I blew a tire on my way figured I could utilize the time to make a post while I waited
@jakenorthey Really unfortunate series of events. Sorry to hear that man.
@jakenorthey - This is very fixable! If the shell is still good or can be soldered, otherwise I just tend to replace the part as a hot air rework system will make quick work of it putting a new one.
Forget an external setup as you won’t find a USB WiFi Version, at best you’ll need to get a USB-C to Ethernet then using a WiFi repeater not worth the hassel.
Don’t glue! A good micro-soldier tech can replace the connector.
Can you tell use where you live country and nearest sizable city. Maybe we can aim you to someone
Jake Northey crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 61
