Ninth generation of iPad, released September 24, 2021, available in 64 or 256 GB models. Model Number A2602.
Ipad 9th gen charging port
Charging port Connection thats soldered to the motherboard damaged. Can i replace without replacing the whole motherboard? Dont even know what it would be called. It’s the part that connects the charging port to the end of the mother board that gets soldered???? Any help? Thanks in advance.
Hi, can you provide some more information about the iPad, like the model “A number”?
Hi,
Yes you can replace the flex that is damaged at the mainboard end, they are available but you need the exact model of the iPad to get the correct replacement flex.
The charge port replacement comes with the flex to the mainboard, but it does need to be soldered into place, if you have no experience then you will need to have a repair shop do this for you.
Hope this helps
Warriorprincess crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 58
crwdns2936753:030crwdne2936753:0 215
crwdns2942667:0crwdne2942667:0 2,213
