Released in 2021, this lineup of the F15's features an Intel i5 or i7 processor, NVIDIA GeForce RTX GPU, and 15.6 inch 1080p display. These laptops have a sleek design and hardware optimized for performance-driven gaming at a lower price level.
My Laptop is not charging
I have plug my charger no indication of charging and my laptop is not turning on
  1. ensure the charger cords has no kinks or tears, then plug into an outlet with power.
  2. Check the chargers power supply box(if it has one), usually has a light(green LED) to tell you it's powered on and in working condition.
  3. Ensure that inside the charging port on PC is clean and not broken.
  4. Make sure battery is connected.
  5. Plug it in and it should work.
Let me know if that helped, and I used to tug on my charging cord all the time years ago. That inevitably broke the port inside the computer to charge it and like an idiot I threw the entire laptop out. Now I know I can take it apart and at least rig it(if not replace the broken spot) I DO NOT RECOMEND unless you know what you are doing.
Anyways best of luck, computers are fragile and taking care of them is important.
nah, charger has no kinks and tear, as well as charging port has no dirt inside, my unit is 8 months old.
Is the LED light on the power supply(box thats in the middle of charger cord) on?
And if you shake the PC gently does it rattle? Can you remember the last thing you did with your PC? Like disable anything, messed with settings, or deleted any files?
troubleshooting order:
  1. Verify the charger is OK by measuring the voltage or plugging into another similar computer.
  2. Verify the socket of the computer is clean and not broken.
  3. Remove the battery and plug in the charger. Most LT will run with just the charger. If it does, that would indicate a battery issue.
  4. If none of that works, you will have to open it up, repeat #2 and verify all the cables are secure - disconnect them and reconnect them. Be careful, those connectors are easily broken if you don't open them properly. Search for how to do it for your connectors.
  5. Panic - at this point it is either the power PCB, if there is one, or the MB.
Michael Micabalo crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 121
