The OnePlus 9 5G is a mid-range smartphone, released in March, 2021. It's the successor of the OnePlus 8 and features a 6.55" 120 Hz Fluid AMOLED and runs on a Qualcomm SM8350 Snapdragon 888 5G chipset.
Where to find UEF01A usb flex cable?
I have a OnePlus 9 5G model LE2115 and need a USB flex cable. The OEM part has UEF01A part number on it. There are sites (Amazon, eBay) showing LE2115 USB flex cable but the part they offer for this is UEE107 but that is not the right part.
Attached is a picture of the OEM flex cable from my phone.
Going to answer my own question. Turns out that the USB flex cable UEE003 made for the OnePlus 9 Pro will work for the OnePlus 9 5G LE2115.
However worth noting that the connector that connects to the mainboard does not align perfectly like the exact flex cable would, but you can move it over just enough to properly connect. It may be easier to connect the flex cable to the mainboard first and then situate the USB port end into the location at the bottom of the phone housing. The USB port works fine for charging and with a USB headphone dongle, so conclusively the UEE003 is wired exactly like the UEF01A.
Hope this information may help anyone else looking for a replacement USB port for a OnePlus 9 5G LE2115 or similar variant.
Same issue for me, with exact same cable. Found a match on ebay (seller was "in-and-out-wireless")...listing had four different options to choose from, and as noted above, the cable for the 9R was an exact match. (Make sure to look at the pictures and match to your cable. Listing photos in this case showed all #s clearly, which was nice). Swapped it in a couple of days ago - perfect fit and it works.
@jbooth24977 just to add to the compatibility answer you've provided. The UEF01A flex cable is actually standard for a OnePlus 9R model LE2101 and LE2100
Thank you @oldturkey03. Wish I could have known sooner. Now I know what to look for should this ever need to be replaced again. None of the online sellers that claim to have the right one for my LE2115 are selling the right cable.
This is wrong information. I have two USB ribbon cables for the 9R, which is part number UEE013 and it does not fit model number LE2115.
These ribbon cables have to be the exact same part number as the one you're replacing. I ended up ordering the needed UEF01A cable from a seller in China.
It seems like we can't reliably use the stated model number of these phones to locate the right part. The Chinese seller had the UEF01A showing in the picture of the part.
J Booth crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 188
