The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
Non-responsive with battery connected
Have a strange issue. My elite 2 controller is completely non-responsive when the battery is connected. Won't power on, charge, or anything. BUT it works when plugged in via usb without the battery connected. As soon as I reassemble the back plate and connect the battery, the controller is completely dead.
Useful diagnostic info:
  • battery is delivering power and not damaged
  • no liquid damage to controller
  • no visible corrosion on battery connectors
What is going on????
Are you using a battery pack? Or just 2 AA batteries? Did you tried both to test the controller? Is the controller up to date? When using a battery pack, which brand? The one from Microsoft?
This is an elite series 2...the battery is built-in, not AA replaceable. The battery is original.
Hi Matthew! Sry! Okay the easiest thing to try is a new battery pack and see if that solves it! If not, it’s motherboard related. Controller is up to date?
The controller is up to date. I just put the controller back together and while securing the back plate onto the board housing the controller turned on. Once I screwed the back plate onto the housing completely, the controller is now no longer responsive. Could there be a faulty or loose connection? The three pin battery terminal doesn't appear damaged.
Thoughts?
Hi! Could be, or something is causing a short. Can you check if the screws are not touching the motherboard? Also check the cables to see if they are free when closing the back plate.
Matthew Riordan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 86
