Repair information for the SteelSeries Arctis Pro wireless headphones. Released in March of 2018. Model number: 61743.
How repairable is the hardware microphone mute button?
The mute button for the microphone seems to have a loose connection, as when I turn the mute on or off, it beeps and randomly activates/ deactivates the hardware mute until I tap the left earpiece. I'd rather avoid replacing the whole headset due to the price.
Somone said they used wd-40 contact electric spray on it and that solved it, others say you keep pressing and unpressimg the mute button, if you still have warranty contact manufacturer.
If you're a tinkerer you can disassemble the headset and clean the mute button from the inside, if that doesn't solve it then I would put a small solder point on its tip from the inside and keep it unmuted all the time and not play with it, maybe use software matting instead after.
Corey Sutlief crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 105
