In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
How to put off the maintenance light
I have the method of removing one of the battery terminal and replaced after few seconds but it does not work
Sorry you don’t have enough information about the problem.
Just turning light off is not a fix if cause is not known.
Your maintenance light will illuminate when it's time to schedule a service, so it's important to stay up-to-date on your oil changes and tire rotations. But if you take care of your routine maintenance at home, you might need to reset the light manually.
  • Place your key in the ignition and turn to the "on" position, but do not start the vehicle.
  • Press and hold the trip reset button until "Trip A" pops on the screen.
  • Turn your key back to the "off" position.
  • Press the button to reset the trip and turn the key back to the "on" position.
  • If the miles section of the odometer suddenly flashes zero, you've successfully reset the maintenance light.
What if your attempt didn't work? Try again. Sometimes it takes a few tries to get the timing right.
Olasunkanmi Saheed Fadipe crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 85
