The Xiaomi Poco F3 has a 6.67-inch AMOLED display with a refresh rate of 120 Hz and a touch sampling rate of 360 Hz. It is powered by the Snapdragon 870 5G. Released in March 2021.
Battery charge not showing correctly.
My Poco F3 still charges however the battery percentage shown on screen does not increase from whatever was showing when charging started. When it is disconnected from the charger it continues to show the phone discharging until it gets to 0% and switches off. I then turn it back on and it jumps up to 85% charge and continues to work and discharge until it actually runs out of power and turns off at some "random" charge %. It then tries to turn back on but turns off during power on sequence. I then place it on charge and it turns back on and shows 85%. I'll leave it on charge for a while at 85% then the cycle begins again.
My problem,after I put charger cable, sometimes ok,Sometimes I have to shake the wire, and if I shake it a little hard, the charge doesn't come in. Is the place where the head of the charging wire fits? The tin may be cracked, the shoulder may be damaged, or something else. I'm asking for help from the experts here.
@gmc46728 the State of Charge is reported from the battery to the phone. This could be an issue with a failed battery control board. I would suggest that you replace the battery and then re-evaluate. Use this guide Poco F3 Battery Replacement to replace the battery. Replacement batteries are readily available at many online stores.
GMC crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 831
