Repair guides and support for desktop computers produced by Asus including towers and all-in-one display PCs.
BOOT ERROR...usb device over current status detected...
so randomly ...i was booting my Tuf Gaming x570 pro (wifi) when i got this error.. "usb device over current ststus detected. System will shut down in 15 seconds." i have read a few stories and watched some videos about this but really there is not alot on this specific error and i am left in same place i was before it started ...clueless and unaware. i seen one person suggested one of my usb ports could have something stuck or broken inside and that i should check all my usb ports internally and externally. There was nothing noticable with the eye. i started removing and testing several periphials and kept attempting to post with no success. i seen that one place suggested i pull and reset cmos which i have done. i also have disconnected all rgb and argb connections and removed the extra storage drives and still keep getting same error. i tried to get into bios several times however the hotkeys are not working. the one thing i thought i could try was flash the bios however my board requires me to remove cpu to do that and i will gladly if that is what i need to do but a full rebuild was not my idea of a good time either lol. So here i am asking all you fine technicians both amature and expert for any kind of experience with this and please share your solution or knowledge on this error. i guess i should use my tpm diagnostic tool and see if i can get a code. i will give it 1 more day and get some more advise or knowledge and opinions and go from there.
HERE ARE SOME SPECS...
  • ASUS TUF GAMING X570 PRO (WIFI) AMD AM4 ATX
  • RYZEN 7 5700X 3D
  • VENGENCE RGB PRO 32GB (2X16GB) DDR4 DRAM 3600MHZ
  • ROG STRIX HELIOS MID SIZED ATX CASE
  • NZXT KRAKEN Z73 LIQUID COOLER
  • WINDOWS 11
Hi @michaelclu56125
What USB devices are connected to the PC?
Did you try disconnecting all USB devices at once and check if the PC passed POST.
Usually these days keyboards aren't necessary anymore to pass POST as was the case years ago, but maybe not. If so leave only the keyboard connected (if a USB type) and then try.
If still no good try disconnecting the cables connecting the USB ports to the motherboard (obviously not the hard mounted ports on the rear on the motherboard) and check (see #8, 9 &10 on p.14 of 68 (pdf numbering) of the user manual for location of cables)
What is the make and model number of the PSU?
Michael Cluney (Mike) crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 37
crwdns2959996:0crwdne2959996:0 719
