Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
crwdns2934591:02375crwdne2934591:0 crwdns2934593:0crwdne2934593:0
crwdns2934055:0crwdne2934055:0
Digitizer not functioning well.
iphone4 16gb stop responding to touch after talked on the phone. it was working well before i listened to call for near about 40min. after disconnecting the call touch of phone not working. i restored the phone 2 times. check the internals . nothing found out. changed the screen 3 times from the market and 1 from the working phone. touch of this phone is working in another phone but not in this phone. i takes out the logic board and remained un contacted from battery for 30 mins but still same . logic board looks fresh. phone never opened before. i checked only. help.........
First, this is going to need a new display assembly. If that doesn't work, then it's the motherboard in the phone, or simply a defective replacement. Get another one if this is the case to confirm.
iPhone 4 Display Assembly Replacement
Should this be the motherboard, don't bother fixing it. The boards cost more then a phone and you have to be careful, since some of them are IMEI/ESN blocked. You can't verify a lot of these, since some sellers don't know or evade the question for obvious reason. I wouldn't bother.
They can also cost more then the phone is worth at times.
i changed so many . the problem is in the logic board . have any idea ? i found 2 chips are responsible for this but very hard to get that .
You need to know compoent level soldering, whicj is that tough
yup i will try with that . otherwise last option is to replace the logic board
like I said, you need to compare the cost and find the best deal, DO NOT buy used boards due to the IMEI block risk, only time you do is if you get a cracked 4 on craigslist and it is not stolen, and the IMEI is clean and checkable
Here in india apple is replacing the phone on chargeable basis. i will go there becoz they are giving a new phone. then thats it the better option.
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 1,832
