MacBook after cleaning wont turn on without adapter
Hello,
I decided to clean my MacBook since it was overheating etc. I cleaned the inside of it together with one fan. Changed the thermal paste on cpu for a new one. After assembly I found out that the computer won’t power on.. only by using adapter. Battery was working fine before. What could be the issue?
Update (05/12/24)
I thought it was working for a while, but probably some kind of bug, because when Im on windows through bootcamp it also shows me 92%
IDK what happened, but it went from this
to this
When I unplug it from charger it dies.
Tried unplugging and plugging back the connectors that are going from battery to MOBO
but nothing..
I ran the diagnostics and its saying that It found no issues - reference code : ADP000
Update (05/13/24)
Bought a new battery with new ribbon cable and now it seems to work fine.
Probably a ribbon cable was damaged.
@adamskrobak - Well not good😫
Your battery is over the 1k of charging cycles so it was on fumes! That’s why the health score is Poor.
Independent of that you may have a logic board issue with the charging logic. Let’s see if we get any errors running the onboard diagnostics, restart the system and the. Press the D key just after the system restarts to enter into diags, let us know if you get any errors and what they are.
Reference: Mac startup key combinations
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
@danj
I was thinking about getting the mobo out of the shell again and try to go step by step. Can I contact you somewhere?
crwdns2934271:0crwdnd2934271:0 Adam Škrobák crwdne2934271:0
@adamskrobak - At this point it’s a bit of a gamble. So diags eliminated most of the other deeper issues, it still has its limits and sadly it can’t test the charging logic.
So… You need to find someone locally who can fix your logic board and replace the battery. You could replace the battery your self, but then yo still need to fix the logic board, which is not that big a deal if you have the needed tools, skills and access to the needed parts.
Where do you live? Country and nearest major city.
@danj i took it apart gently and putted it all together and now it’s saying that there is no battery inside🤷🏻♂️ I live in Czech Republic Prague
@danj So I replaced the battery, but Im struggling to put the ribbon cable inside. Even though it seems like the same size as the older one Im unable to fully lock it in... any tips?
crwdns2934275:07crwdne2934275:0
