Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
iPhone Rear housing replacing issue
Hello,
I have a interesting issue/question. Maybe someone had same issue and can help me out.
Phone is iphone se 2020. Back glass is cracked and the metal frame part next to camera was so damaged that new housing was a must.
After replacing the housing (non original) the device boots up but does not charge via cable, only wireless charging works. i tried replace charging port with originals and also non original and the issue persists, but then i swapped the logicboard with screen into other iphone(iphone 8) housing(iphone 8 housing had all original 8 parts except logicboard, display and battery) and everything works flawless, after that i swapped it back into new chines housing and guess what the same issue is back again. Does not charge via cable. Looks somekind issue with ground i quess.
At this point im pretty sure, that the logicboard and also the original charging port are not damaged.
Hi Carel, yeah my guess is either a grounding issue or a component that it doesn't like.
Best of luck, BetaTech Labs Repair AU
carel crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 165
