Temperature error in FaceTime
Hey guys. I’ve been working on the Mac recently, and it’s been giving me a headache. I recently solved a problem with it running extremely slow, thinking that the Mac detected my replaced battery and rejected it. Eventually the performance increased a little, but not much. Now when I head into FaceTime, it simply states “Temperature: Video will resume when Mac cools down.” I understand that could be an issue except the Mac is not even warm. I left it off all night and just woke it up to see if something changed, but the error remains.
It makes me think that the issue I was dealing with about it running extremely slow was related to this. I think the Mac’s thermal sensors think the Mac is very hot and needs to cool, therefore lowering the performance. So, is there an easy way to fix this? Or would it require a Logic Board replacement?
Alright here’s what I found:
Ran Diagnostics.
FaceTime Still needs help.
Photos hasn’t synced in hours.
And I got this app…
And now I’m getting this error
I did try to replace the Trackpad flex cable, but as you can see, the one on the right it the replacement, the cable was defective when I got it.
I would like to say, after playing around with that app, I found the Mac was registering 122 degrees Fahrenheit. The Mac was also cold… something is definitely wrong
crwdns2957956:0crwdnd2957956:0 Jadon Lyon crwdne2957956:0
@jadonlyon - Well it does appear you have a sensor which is either seeing a heat issue or is faulty. SMC is seeing a failure and so is TG Pro. So, is the battery or the trackpad needs replacing? Do you have access an IR detector to identify the hot spot?
crwdns2957956:0crwdnd2957956:0 DanJ crwdne2957956:0
@danj - What's terrible is that I just replaced the battery following iFixit's guide... according to this post that I just finished asking: Mac slows drastically after battery change , the battery is in a good condition, and is working just fine.
@danj - And, no, I do not have an IR camera, sadly. I have been trying to feel where the Mac gets hot with my hands (I know that is not as accurate) and really it hasn't gotten hot at all up until I start copying large files to the internal drive. Like when I am downloading apps from the App Store. It will download very quickly, but then take forever to install. That's when I feel heat coming from where the logic board is.
@jadonlyon - I do remember your older post. So which do you think is bad? I’m suspecting the trackpad got damaged in the battery replacement process. I would make a through inspection of both the trackpad and the cable for damage. But I can’t swear to that!
