2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Dead power button fix
My 2015 MBP has a dead power button. I have determined that it is completely dead at the contact pad as if I touch it with something metal, it doesn't work. Every other key works. Is there something I can do, or does the whole keyboard need replacing?
To be clear, you are able to power on the system by shorting out the Power Pads, so it’s clearly the button that’s failed.
I haven't tried that. I may have to replace the entire top case.
@sickminecraft45 - I would start off checking if you can bypass the keyboard first.
Sickminecraft45 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 78
