A LED bulb 230V is a type of light bulb that uses Light Emitting Diodes (LEDs) as a source of illumination and is designed to operate at a voltage of 230 volts. This type of bulb is commonly used in areas with higher voltage electrical systems, such as in Europe and other parts of the world that use 220-240V AC power.
Led bulb 120wt repair
Led light bulb 💡 repair
Charging LED bulb repair
Yes my led bulb is dead
@hamzajutt you're really not giving us much to work with. It would be nice if you would at least tell us what your bulb does, what happened to it and what you have already checked.
Here is a generic answer. Take a look at this teardown LED Light Bulb Teardown It will show you how to get into one of those and this one LED Birne Lampe 230V E27 defekt reparieren will show you how to check and possibly repair the bulb. You need to check the LED's, the capacitors as well as the LED driver. Let us know if you need more assistance with that and you can always post images of your bulb components and circuit board with your question. Adding images to an existing question
crwdns2886500:0iFixitcrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937585:0crwdne2937585:0
2 - 5 minutes
crwdns2886500:0LED Birne 230V LEDcrwdne2886500:0
LED bulb lamp 230V E27 defective repair
crwdns2937801:0crwdne2937801:0
30 minutes
crwdns2886500:0LED Birne 230Vcrwdne2886500:0
Como puedo reparar mi ampolletas Led quemadas?
Como puedo arreglar mis ampolletas Led quemadas
@victormarcelo the guides in the original answer should help. The LEDs are usually soldered to the circuit board.
@victormarcelo Las guías de la respuesta original deberían ser útiles. Los LED suelen estar soldados a la placa de circuito.
Hamza Jutt crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 664
