Led bulb 120wt repair
Led light bulb 💡 repair
@hamzajutt you're really not giving us much to work with. It would be nice if you would at least tell us what your bulb does, what happened to it and what you have already checked.
Here is a generic answer. Take a look at this teardown LED Light Bulb Teardown It will show you how to get into one of those and this one LED Birne Lampe 230V E27 defekt reparieren will show you how to check and possibly repair the bulb. You need to check the LED's, the capacitors as well as the LED driver. Let us know if you need more assistance with that and you can always post images of your bulb components and circuit board with your question. Adding images to an existing question
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937585:0crwdne2937585:0
2 - 5 minutes
crwdns2937801:0crwdne2937801:0
30 minutes
Como puedo reparar mi ampolletas Led quemadas?
Como puedo arreglar mis ampolletas Led quemadas
@victormarcelo the guides in the original answer should help. The LEDs are usually soldered to the circuit board.
@victormarcelo Las guÃas de la respuesta original deberÃan ser útiles. Los LED suelen estar soldados a la placa de circuito.
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 878
Charging LED bulb repair
crwdns2934271:0crwdnd2934271:0 Satya Narayan sahoo crwdne2934271:0
Yes my led bulb is dead
crwdns2934271:0crwdnd2934271:0 Ashvini Vaidya crwdne2934271:0
