Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
Replace the thermal grease/paste
There is no guide yet on how to replace the thermal grease/paste.
These Macbooks are now around 4-5 years so it's not a bad idea to replace the thermal paste.
They're not obsolute so there will still be users who can benefit from a guide.
Update (04/01/24)
Update:
So I was able to open the MacBook and disassemble the motherboard with the video.
Since I'm comfortable around electronics (this isn't my first time opening up a MacBook, laptop, or even a smartphone), I did choose to replace the thermal paste on the cpu and gpu.
And honestly, after four years of service... Kind of disappointed about the original paste. Dan said that paste will last longer now due to improvements, but the original paste was crumbly as hell. Furthermore I noticed small blank spots on the cpu and it's heatsink, so not very good spread. The gpu did have a good spread. They definitely were generous with the paste on the gpu, because its surroundings were covered with paste too.
Cleaning wasn't difficult, as I said the paste was in a very crumbly state.
After cleaning I gave the copper plates of the heatsink and the cpu and gpu some time to evaporate the alcohol.
I used Noctua NT-H2 and used the "X" to spread the paste on both cpu and gpu.
The only annoying experience was to place back the motherboard in the case. I needed multiple attempts because there was always some small connector/ribbon cable underneath the motherboard. Ugh! After playing like an octopus for a while, I was able to place the motherboard back and with all connectors/ribbon cables out on top of it.
It's do-able but only for people who have a steady hand and... most of all... lots and lots of patience. Take your time. Take some breaks if you get tired or frustrated because the moment that you attempt to work a bit faster or anything like that... something will go wrong. I 100% guarantee that.
I made only one mistake. The connector cable from the left fan is incredibely fragile due to its L-shape (that's what I think). In trying to get the L-shape cable from underneath the board to the top on the board, I got a small tear in the ribbon cable. This fan no longer works. We learn from our mistakes. Should've taped the connector on top of the fan, I wouldn't had an issue to "fish" for the cable since it can't get trapped underneath the board that way. Already ordered a replacement fan.
The temperatures are amazing though. In idle I went from 60-63° to 46-51°. The one remaining fan is also a lot quieter. I'm not going to claim this huge difference to the new paste though. There was so much built up dust in the MacBook... I was genuinely surprised that the MacBook didn't have much higher temps in idle. Both fans were completly covered up in thick dust, and the outlets on both fans same thing. How it managed to get some kind of airflow through those thick dust is a mystery to me.
Anyway, I am very happy with the result. Yes, I did damage one fan connector, but one can only learn with making mishaps.
Ah! The lack of wetness issue. The silicon oil is just a carrier for the solids which is doing the job! So yes it is dry, but that’s not the material which is wicking the heat away.
You are right that there should be a guide, however for the time being, here is a great video.
https://www.youtube.com/watch?v=EGW9RAkl...
I hope this helps.
We can’t be dependent on the fantastic iFixit staff to create all of the guides. We also need volunteers to create content as well.
Time charges things! In years past the TIM paste was still based on old formulations which tended to break down. Todays TIM is much better! I doubt you’ll need to refresh it to gain enough performance improvement for the amount of work and risk if you’ve not done it a few times before.
I would focus in keeping the fans and heatsink fins clean of dust and debris, as well as dusting off the logic board as well if it’s coated up. I also recommend installing a good thermal monitoring app so you can watch things over time. I find TG Pro is one of the best and it allows you to export the data to a spreadsheet so you can track over days, months or years how your system is doing thermally.
Is it absolutely necessary to go through the long disassembly of the motherboard just to change out the thermal paste? Is it only in the much older versions that one could access the fans and change out the paste easily?
@alanbernst72991 Alan, it really depends on which model you have. Things change over the years, so it's hard to give you a definitive answer without knowing which one you have.
I’m very confused by how this msg board works as I don’t see my previous msg, nor the response I kindly received via email about whether it is nessessary to completely remove the motherboard in order to replace the thermal paste on my MacBook Pro 2019 (intel) 16”; that response being it depends on the model which I’d neglected to add.
It is model A2141. 2.3 ghz 8 core i9.
Updated recently to OS Sequioa from Monterey and it’s starts off nearly at 100C but drops after that to below 50C. The insides have never been cleaned so that’s in order, but I’m now concerned about crumbling thermal paste. I certainly don’t feel confident about doing the extensive motherboard removal, but think I could handle it otherwise, as seen in some videos that show fan removals and paste replacement done without motherboard removal.
@alanbernst72991 - you buried it within the question which hides it, then as you hadn't stated you had the same model Jerry gave you a generic answer.
OK, getting to your question yes in this series you do need to remove the logic board as the screws which hold it on are threaded from the other side. Take a look at Step 7 in this MacBook Pro 16" 2019 Teardown note the screw standoffs on both heat sinks and the holes in the logic board. Here's a similar system guide MacBook Pro 16" 2021 Heat Sink Replacement
Thank you. I hadn’t seen this tear down. It’s very obvious what you point out.
lighscan crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 29
crwdns2936753:07crwdne2936753:0 179
crwdns2936753:030crwdne2936753:0 624
crwdns2942667:0crwdne2942667:0 5,208
