Monochrome laser printer introduced in 2012. The printer is rated for 35 PPM and the first page comes out in 8 seconds. Depending on which model you own (a/n/dw/dn/dne), you will have different options and available features. Uses HP 80A/80X toner cartridges.
crwdns2934591:019crwdne2934591:0 crwdns2934593:0crwdne2934593:0
After replacing rollers & pads still getting 'No paper in pickup' err
I replace all of the rollers and pads in my LaserJet400 when both the manual feed and paper tray feed both stopped working (as per this post).
After replacing all of the rollers the manual feeder is working perfectly but the regular paper tray feed is still totally not working. If I try to print with the tray out (and bypassing the tray sensor) I do see the roller spinning to try to pickup the paper, but with the tray in it never grabs the paper.
What else can I look at or replace?
Update (03/30/24)
Just tried switching the rollers but no dice.
I think the one on the left with the black is the original HP part and the the white on both sides is the new roller.
The one on the right has more texture to the rubber as you can see in the picture, the left one is pretty smooth.
crwdns2942205:01crwdne2942205:0
I put back the old separator (which is clearly indented and more used than the new one) and new roller and the the tray feeds.
Guess you cant expect more from a junk Chinese part!
Will have to exchange from Amazon.
Thank you so much for your help and time
Looks to be installed correctly - I just removed it and reinstalled it anyway. it does spin correctly when the printer tries to print but no paper is picked up.
could it be something in the paper tray?
Did you change the main roller and add those rubber side rollers, or change it all down there? That looks like the original HP pickup roller. It looks like the original to me because you see how rotten the one in the printer I showed you on.
There is a separator pad in the tray. Hold on, let me show that.
The rubber side rollers came wit the new kit. My old rollers are just white plastic. I thought I changed the center pickup roller for the new one, but maybe I ended up putting back the old one by mistake? !!
trying the 'old' center roller now...
I did change the separator in the tray already
@jack74681 My dne's (and n) have white rollers. To my knowledge, those are OEM. I know my n is OEM HP.
@jack74681 https://www.ebay.com/itm/380705415099
I got a set from him for my own dne with issues at ~25k pages, they feel as good as the old HP OEM part.
The Tray 2 roller doesn’t have a separation pad like Tray 1. The replacement roller has more than likely not been installed correctly. There’s a clip on the Tray 2 roller that needs to be locked in; otherwise, it will produce that error. If the clip is secure, the roller is bad, or the installation is incorrect.
I don’t have a photo for it, but if it continues, it could be the gearbox. That repair is much more complex. Up to you if you want another M401 at that point (the reason I say that is these are aging, and can struggle with some complex documents that never gave me grief 8+ years ago, even on a base 128MB n and a 256MB dne with lesser processing delays), but if you do check the PC; you want one with ~25k or less if you can; but if it's higher, plan on the rollers needing replacement sooner rather than later. For example, the printer I pulled those from (M401dne) has 25k pages and needs rollers, but I have also seen them run with original rollers with 100k pages before they wear out; it depends on how the printer was used before I got it. The one I showed you the brief procedure on had problems out of the box :(. I never heard back, so I'm going to swap the rollers since I confirmed it's good otherwise. I'm doing the roller repair if I don't hear back as I can't be bothered to chase the guy down to send it back, given this is a ~40lb printer. It's due to a bad roller, but one side is shiny. This can easily be repaired for $25, but I need to do both.
In most cases, you also need to replace the Tray 2 separator since they wear together most of the time, but some can be inspected and reused. Removal is done by loosening those screws (PH2) and installing the replacement.
So I ended up pulling this out of my own in production M401dne as it had the early symptoms of needing this done, which is essentially double-picking issues that WILL get worse and leads to deeper issues that just outright jam the printer:
It picked up 2 pages but worked fine. I addressed it now because the parts are so cheap, and this is an M401dne; it has a duplexer. It's not a problem you ignore on duplex models, given that it can cause you some grief if it jams.
Jack crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 145
