Device and repair guides for the gaming and high-performance laptop computers in the Dell's XPS (Xtreme Performance System) line of products.
need a fan for XPS 8950
i'm hoping a desktop question is ok... i'm running out of options.
the xps 8950 power supply has 2 of these yate loon fans. its part number is D60BV-12. it's 60x60x25mm, with 3 leads. when i ordered one on amazon i received a version that is 20mm deep with two leads (shipped from china)
somehow the third lead delivers a health signal, because when i installed that fan, system performance dropped by about 50%. performance was fully restored when i put the original noisy fan back in. photo shows the label of the fan i need.
i'll be very grateful to be pointed towards a competent supplier. thanks, all. -mark
crwdns2944067:05crwdne2944067:0
bingo! that's the one.
i really thought after using amazon for fifteen years that my searches were thorough, but i missed this one.
it's not the cpu fan, but rather one of 2 fans on the power supply.
this is exactly what i need.
many thanks!
Seems like the comment was deleted. do you have a link to the replacement fan you got with the 3 pin connection? I have the same issue with the noisy PSU fan
Hi Sam -
here is the item from amazon that worked for me
"D60BV-12 12V 0.50A 6025 Cooling Fan 60X60X25MM 3-Wire"
https://www.amazon.com/gp/product/B0CPCR...
additional note - the connector on this new fan did not match the physical configuration of the mating plug on the motherboard. so, i cut the connector off the original fan and soldered it to the new fan - black to black, red to red, and yellow to yellow. this worked fine.
Thank you!! Just did the fix and everything worked.
@samcirola -- wow, that was quick! you don't mess around.
@junior_varsity absolutely is this question okay. We are not brand or device focused, with us it's all about repair and helping people to fix their devices.
If this is the processor fan then the part number can vary. Most commonly it is a GPR6P MXY5H, GPR6P 0GPR6P or a 76pc8 for the water cooled 125W CPU
If you want to stick with a Yate Loon fan then get the d60BV-12 3 wire version from places like this
Repair is War on Entropy!
mark klemick crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 397
