2012 Door window dont work
2012 ford expedition door window repair
Update (03/17/24)
2012 ford expeditiondoor window its stuock
Have you checked the fusebox for broken fuses or breaks in cables related to the window? Anything blocking it from moving? A broken hoist mechanism for the window inside the door can also give these problems.
Most likely a broke window regulator motor those go bad causing the window to be stuck
Problems with the automatic transmission
when it is hot it disconnects and does not work properly
When it is hot it disconnects and does not work properly
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 71
