The Ford Expedition is a full-size SUV assembled by the American automaker Ford Motor Company. Introduced as the four-door successor of the two-door Ford Bronco, the Expedition has remained in production since the 1997 model year; it is currently in its third model generation.
2012 Door window dont work
2012 ford expedition door window repair
Update (03/17/24)
2012 ford expeditiondoor window its stuock
Have you checked the fusebox for broken fuses or breaks in cables related to the window? Anything blocking it from moving? A broken hoist mechanism for the window inside the door can also give these problems.
Most likely a broke window regulator motor those go bad causing the window to be stuck
Problems with the automatic transmission
Update (09/13/24)
when it is hot it disconnects and does not work properly
When it is hot it disconnects and does not work properly
Ama crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 278
