Creality 3D is a brand of 3D printers manufactured by the Chinese company Shenzhen Creality 3D Technology Co., Ltd. Creality 3D printers are known for their affordability, reliability, and user-friendly design.
Why is my bed acting up?
I leveled out the bed on all 4 corners but when I get to the middle its all loose there making the filament not stick correctly
I'm not familiar with this printer, but:
  1. "Loose" does not describe anything I can relate to.
  2. Placing the straight edge of a steel ruler from corner to corner might tell you if there is a dip there if that is what you are refering to.
  3. Knowing how you leveled the 4 corners might help with the analysis of the problem.
  4. You can print a flat object from corner to center (move it from the default center position) to see if it is only not sticking in the center.
  5. If it also doesn't stick on the corner, your Z offset may be the problem, or your Z endstop may be loose or inconsistent.
your best option is to get a glass bed for your printer. Creality is known for their uneven or beds with a dip in the middle.
Unknown Darkhawk crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 53
