The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
Nintendo 2DS Touch Screen not working
Hello, my Nintendo 2DS Touchscreen is not working how do I fix it and what do I need (the bottom and top ONLY register touch)
@maximusgabriel, can you clarify the problem you're seeing? I can't quite make out what it is you're trying to describe. You mention a touch screen issue, implying it's not the LCD but rather the digitizer that's the problem, but then you say the bottom and top ONLY (?) register touch. I don't understand what you mean by that, so if you could elaborate we'll be in a much better position to help you figure out what's wrong.
@dadibrokeit
The bottom and the top of the Bottom screen only register touch
You will likely need to buy a replacement screen and follow this procedure. The screen should come with the touch digitizer which seems to be the problematic component in your device.
Maximus Gabriel crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 449
